Attribute not displaying in table
383
04-03-2023 12:18 PM
SLouq
by MVP Regular Contributor
I have a web service layer in a web map which when I open the attribute table the attributes are hidden. The attributes are there because they display in the web map, they are just hidden in the attribute table. How do I unhide the attributes? I am opening the map in map viewer
KenBuja
MVP Esteemed Contributor
In the New Map Viewer, click on the setting icon in the table. This will open a list of fields that you can turn on or off.
In Map Viewer Classic, open the hamburger menu on the right side of the table and select "Show/Hide Columns"
In Classic, when you configure the popup, changing the display fields in the Configure Attributes window will affect which ones show up in the table view.
SLouq
Thanks for the reply!
I get how to turn fields on and off but it's the attributes which are not showing.
That is what I can't figure out
ShawnJanuar
Hi!
I'm experiencing the same issue. Did you manage to find a solution?
