ArcGIS Arcade return x coordinate of web map feature from EPSG: 3857 to EPSG: 2227
336
02-21-2024 11:17 AM
AlcoGISUser
I'm using smart forms in ArcGIS Field Maps and I need to calculate the x coordinate in the feature layer's original coordinate system (California state plane III, EPSG:2227) when a new feature is added to the map.
The feature layer was originally in 2227 when published to AGOL but when I try to use the geometry function in Arcade it uses 3857 (web map coordinates).
Geometry($originalFeature)["x"]
returns:
number: -13610189.8467
snyway I can add a parameter like "spatialReference": 2227 to get the expression to return values in state plane?
RhettZufelt
MVP Notable Contributor
Not sure if it is an option for you, but if you create your own basemaps in EPSG:2227 and use that in the web map, then the entire web map will be in that coordinate system and
Geometry($feature).X
will report the coordinate in the state plane system.
I do all my AGOL stuff in state plane in order to avoid these issues.
R_
