When editing a line feature in a web map, you can enable the Tooltips and get the total length of the segment. If you edit a polygon feature, you only get the area....It would be nice if the Total Length of a segment would also be display when creating a polygon.
Hi @DominicRoberge2,
We've updated tooltips to show the length of the segment when creating polygons as well. The Distance field represents the distance from the previous vertex to the cursor:
Check out this article to learn more about the latest updates for tooltips and editing: Tighten Up Your Edits with Editing Constraints.
Thanks!
Hi @EmilyGeo
it's a great improvement, thank you! Now if you guys could just add the options to select what type of polygons we want to draw that would be fantastic.
It's available in ArcGIS Earth... why not in a Web Map???
