Has anyone successfully connected monitor 2023.2 to an Oracle geodatabase? We registered a connection but are unable to log the geodatabase metrics.
We only see 4 metrics related to database sessions being observed.
A closer inspection of Monitor debug logs helped us figure out what was going on. We found we had to connect using the SDE account. The three errors below occurred while we were trying to connect our Oracle instance with an account we created that we thought had the proper permissions based on reviewing the Monitor documentation.
So something from the Monitor documentation (https://doc.arcgis.com/en/monitor/2023.2/get-started/windows/register-oracle-databases.htm) that tripped us up:
*What we found is that we needed to be connected as SDE due to errors 1 and 2 above. That wasn’t clear in this step as we read it as any user account with proper privileges to those listed objects provided*
*With error 3 above, perhaps one more grant to add to this list is v$statname
Hi @mgress12,
It appears that this issue requires deeper troubleshooting than what we can do over the forums. Can you please open a support ticket for this issue?
Jen
