We are a research institute in the earth and environment sector. Recently, we used ArcGIS Mission in a campaign for internal communication between research vessels. In addition, the report functionality was used for the necessary station logging. So far so good. The system worked well.
When we analysed the relevant data after completing the mission, we found that the handling of the report data (feature layer) was very complex. In example the Excel export function from the report feature layer didn't provide the clear names of the report attributes. An other issue was by using single choice. In the excel output doesn't appear the clear name of the single choice, but "single_choice_1", "single_choice_2". I know it's not modern using excel sheets and the end...
A colleague of mine works with Survey123 App. And she says this issues are fixed in this solution.
Here my idea: Cobine Survey123 Reporting with ArcGIS mission reporting. The reporting inside of ArcGIS Mission does not appear mature.
Thanks for reading!
Max
