Sidebar Instant App Pop Up Feature Not Working
711
5
04-02-2024 05:44 AM
jvarasanz
The sidebar pop up feature works when a feature is selected for the first time, but stops working afterwards for any other selection. Turning it off makes it work in the map though.
Javier
SarahMcDonald_Esri
Hi @jvarasanz
Thanks for reaching out about this. There is a small issue with the new pop-up panel that was added during the last update. If you switch to use the Classic panel in the app configuration that should resolve the issue you are seeing.
Thanks! 
Sarah
AnneReynolds
THANK YOU!!!
DanielHoffman73
Thank you Sarah, this worked great!
KarenChadwick2
Please note that there's another thread regarding the same issue here: Solved: Instant app Sidebar issue identify after last upda... - Esri Community
MJBiazar
A bug has been logged against this issue and is currently in product plan.
BUG-000166058 - The Info tab in the Instant Apps Sidebar template does not work as expected. When express is turned off and edit is turned on, after the first selection of a feature, the info tab does not display any data.
Best,
MJ
