Public Notification Instant App only exports from related table if layer is public
226
01-03-2025 08:37 AM
hpnels1358
When configuring the Public Notification Instant App, I am unable to export a contact list from my related table unless I share the layer publicly. When the layer is not shared publicly, the Export button just spins. Once I share the layer publicly, it works as designed. I had previously been using the Public Notification widget in Web App Builder where I was able to export a list from a related table without sharing the layer publicly. Will this capability be incorporated into the Public Notification Instant App?
MtProAdmin
I am having the same issue regardless of whether or not the layer is shared publicly. This app used to work well with a map that contained no publicly shared layers. I have tried sharing the layer publicly and still no luck.
ChryseMorales
For the layer, do you have the related record displayed in the popup?
ChryseMorales
Thanks for bringing this to our attention! A defect from Support has been logged (BUG-000173667) if you'd like to track it, and we as a team will look into this more to get it fixed.
