Anyone else encountering this issue?
Map pin is not dropping where the user clicks, thus causing an error in results for Zone Lookup
In the image below, I clicked where the red dot it, but it landed in the road (green pin)
It will use the geocoded address so that is most likely the street centerline in your example. Do you have a public app I can use to test?
