ArcGIS Insights Blog
95
10K
10
Open | I would like to see the ability for multiple images to interact with card filters. For example, in a dropdown selecti... by Elizabeth_Burniston New Contributor III 0 0 | 0 | 0 | |
Open | Please create a connector for Azure Databricks. ESRI support was unable to get me connected to Databricks, even with ... by RyanDickinson1 New Contributor III 2 7 | 2 | 7 | |
Open | ArcGIS Insights should have a cross-tabulation feature, comparable to the basic row-column overlay of Excel Pivot Tab... by RylandLu New Contributor III 0 0 | 0 | 0 | |
Open | Ability to use the Expression Language available in Insights with SQL capability. That is to say functionality like "... by PaulDowning New Contributor II 2 1 | 2 | 1 | |
Open | Self explanatory - I want to access content I've hosted/created on Insights Online through Insights Desktop and vice-... by Rob_Hughes_32Alpha Occasional Contributor 1 10 | 1 | 10 | |
Open | The window doesn't allow you to scroll when there are more option than can fit in the sidebar. This is a very small i... by SaraHedrick1 New Contributor III 1 2 | 1 | 2 | |
Open | Just an idea. I'm evaluating ArcGIS Insights Desktop 2022.2.0.4957 to add to our barrel of BI products. I installed... by TimMinter Occasional Contributor III 1 9 | 1 | 9 | |
Open | I'm working with a large dataset, and I accidently changed a string field to 'Date/Time', and I can't change it back.... by SaraHedrick1 New Contributor III 0 2 | 0 | 2 | |
Open | It is great to have the ability to copy data to Insights, but there doesn't appear to be ability to easily sync the d... by James_Whitacre_PGC New Contributor III 2 0 | 2 | 0 | |
Open | Date/Time on Datasets imported from hosted ArcGIS Online feature layers/tables are currently displayed in UTC.It woul... by GFernando New Contributor III 9 2 | 9 | 2 | |
Open | Good day all,I recently came across the `Geopackage` format to store data. I find it much more stable than a `gdb` es... by Ed_ MVP Regular Contributor 1 0 | 1 | 0 | |
Open | I've been working on a dashboard that contains data with hyperlinks to comptroller documents relating to development ... by LauraBecht Occasional Contributor 2 1 | 2 | 1 | |
Open | Simple idea, perhaps not easy to implement.Use case;I use view layers on larger datasets to give myself a "head start... by JonathanMcDougall Occasional Contributor III 0 4 | 0 | 4 | |
Open | Right now if you want to update data pulled from Sharepoint in your Insights Workbook, you have to manually re-add th... by BryanChastain2 New Contributor III 13 4 | 13 | 4 |
Idea Submission Guidelines
