in ArcGIS Pro 3.0.2 Image Analyst - detect-objects-using-deep-learning tool I get the error 003569 by using the esri trained model "Land Cover Classification (Aerial Imagery)" on a 3 band aerial image with a resolution of 20 cm.
https://www.arcgis.com/home/item.html?id=c1bca075efb145d9a26394b866cd05eb
Deep learning libraries are installed in the right directory as far as I can see?
ExecuteError: Fehler bei Ausführung. Parameter sind ungültig.
ERROR 003569: Ungültiger Deep-Learning-Modelltyp. Modelltyp NULL, ObjectDetection, InstanceDetection, or PanopticSegmenter erwartet.
Fehler beim Ausführen von (DetectObjectsUsingDeepLearning).
I get this error message by drag and drop the dlpk in the toolbox tool?
Any ideas what this error message means?
