There are several methods to add an external page to your Hub site. You could:
1) Link to the page from your Hub header menu using "Add Link > to existing content" if you don't mind the page opening outside the context of Hub.
2) You could iframe the external webpage into a Hub page using our iframe card. You'd likely want to set "Allow Scrolling" to "Auto" and under Appearance > iframe Height, set it to 100vh. You should also open the Row Settings and switch "Layout" to "Wide.
3) If you want the external page to show in your search catalog, you can also add it as a Document Link by going to your Content Library, selecting the New button and then choosing Content. Under the tab "Use URL" paste in your external page link. If you do this and choose to have the "Embedded Links" option off (found under Site > Settings > Interactions), the page will open as a standalone page when selected from your Hub search results or if featured in a Hub gallery card.
