Is there a way to make a field conditional read only in Field Maps?
325
04-27-2022 12:07 PM
SFM_WillBrewer
Currently we have an arcade expression that conditionally hides fields if the record is 'Archived' we jsut include all the information in the pop-up for the field user to see. Works okay. But... if the layer is still editable then technically the user can hit submit on the record, even if not changes are made, and this clears out the values that are hidden in the form by the arcade expression. This is causing data loss issues.
