Fields Maps error arcade expression invalid ERROR code 40
306
02-27-2024 05:23 AM
MorMiftahThiam
Hello community,
Anywone can help me the picture error below when i try to collecte data with arc gis fields maps arcade expression is invalid, Error evaluating Arcade expression for attribute rule "commune" Error Code 44
jcarlson
Do you have access to the expression? Without seeing the Arcade that is trying to evaluate, it's basically impossible to say why it's failing.
- Josh Carlson
Kendall County GIS
