Captured Point Location Jumps Around in Field Maps
426
11-20-2023 11:42 PM
tiztrain
Hey,
Have been playing around in AGOL with a feature service that has a feature layer and 4 related tables. When opening the data in Field Maps, the test point I collected jumps around the map, looks like it is confused by what coordinate system to use or something along those lines.
Took a screen recording and added it below. Is this a configuration issue or a bug that needs to be logged? I am using 'GDA2020 to WGS84 2' transformation.
tiztrain
Was a simple map frame issue when publishing. Thought I had gda2020 setup but had wgs84.
tiztrain
Looks like some kind of coordinate issue. Looks at the screenshots below and the coordinates returned for the same point. This point was captured in Map Viewer.
 2023-11-21 09_19_07-Screenshot_20231121_091608_Field Maps.jpg ‎- Photos.png2023-11-21 09_17_52-Screenshot_20231121_091340_Field Maps.jpg ‎- Photos.png
tiztrain
In Pro I have the layer setup in GDA2020 but after publishing, I checked the REST end point and it comes through in WGS84 as per the screenshots below. Tried publishing again and same issue.
2023-11-21 09_51_07-Layer Properties_ Site.png2023-11-21 09_52_12-BioCondition Template - Overview and 11 more pages - Work - Microsoft​ Edge.png
tiztrain
