Hi there. I'm building a simple ExB app and have two issues with the Search widget which may be related (if not, I can post them separately). The widget is looking at two different data sources: a map layer and World Geocoding Service.
Am I missing some configuration option to address one or both of these issues? If not, I can add these as Ideas.
Thanks!
Derek
Solved! Go to Solution.
Problem 1 is an easy fix. In the builder mode, open up the search result options and check 'Auto Select First Result'.
Problem 2 is some bad design on ESRI's part. I have a fix if you are using developer edition. Open the result-list.tsx, find the onSelectRecord function and add onShowResultButtonclick()
Hi @DerekMStrout,
I've also noticed this, would be useful if this widget is edited.
Thank you,
Wow, @JeffreyThompson2, Problem 1 seems to be working now. I swear it wasn't before, and I had "Auto Select First Result" checked. And we are using the standard ExB version (for now at least), so hopefully this is a popular request and can get implemented. Thanks for the help!
Would you happen to know why the Search widget is not selecting the matching feature when I have the result panel turned off, but works fine when it is turned on?
My experience has 2 maps, the one users interact with and one I'm using for all the fun back end stuff. The search widget is tied to a dedicated search layer in the backend map, and any selection of a feature from the Search layer is tied by actions to the layer controlling the popup as well as the corresponding feature in the user map. With the result panel turned on, it all works as expected with no snags I've come across. However, when I turn that off (so my non-empty searches can open the correct Section View) nothing happens.
