Pop ups stopped displaying when selected from Table widget.
186
a month ago
Labels (2)
jerome6
New Contributor III
For the past 2 months, I've been able to view pop-ups when clicking on a record in the Table widget. Yesterday, it decided to stop opening pop ups but still honors the triggers that I had set up before. What's going on here? Did I turn something off on accident?
TonghuiMing
Hi @jerome6
I gave it a try and the workflow works as expected for me. The change of web map settings might cause it - maybe someone in your org with admin access has disabled the pop-up in MV.
Do you have a sample app to demonstrate the problem that you are having?
jerome6
New Contributor III
Hi Tong, afaik, I'm the only active editor for this project. I edited the pop-up last month and the Table functioned as intended until last Wednesday.
I also created a new test app with completely different datasets, and I ran into the same issue - the widget honors the Trigger settings but will not open the feature's Pop-up. The pop up is enabled in MV. Not really sure what's going on here.
Would it be possible for me to share the app without making it public?
is it possible to share the application without making it public?
TonghuiMing
@jerome6 Emm, that is interesting. You can share the app & web map through a group and add me to that group. You should be able to find my account searching for tonghui/Tonghui Ming.
