Is Experience Builder open source?
329
09-12-2024 02:48 PM
ForrestLin
Is Experience Builder open source? Is the source code in Esri github (https://github.com/esri)?
Looks like this is just  samples:
https://github.com/Esri/arcgis-experience-builder-sdk-resources
Thanks.
Forrest
Tags (1)
Ke_Xu
by Esri Contributor
Hi ForrestLin,
Experience Builder is not open source.
Regarding the source code, Esri does provide some samples and resources related to Experience Builder on GitHub, but the full source code of Experience Builder itself is not available on the Esri GitHub account.
The link you provided, arcgis-experience-builder-sdk-resources, contains samples and resources for the Experience Builder SDK, which developers can use to extend the functionality of Experience Builder.
 To create experiences, you must be a member of an ArcGIS organization with a user type that includes privileges to create content. Experience Builder supports ArcGIS Online and ArcGIS Enterprise 10.6 and later.
Ke
ForrestLin
@Ke_Xu
Thank you for your quick response!
The Experience Builder Widget is responsive. I'm wondering how it's implemented and if it's possible to make calcite-dialog like this.
ForrestLin_1-1726227950064.pngForrestLin_2-1726227957941.pngForrestLin_3-1726227972825.png
https://experience.arcgis.com/experience/42818c03ae384edc91ab658faf2664e0
https://community.esri.com/t5/calcite-design-system-ideas/make-calcite-dialog-responsive/idi-p/15380...
Regards,
Forrest
Ke_Xu
by Esri Contributor
ForrestLin
@Ke_Xu
I'll look into it.
Thank you!
Forrest
