I would like to limit an export from a table widget in Experience Builder to only csv files
203
11-01-2024 09:06 AM
DeniseWesleyWildlife
When I try to configure the widget settings in Experience Builder to export only a csv, I am getting a message that this is configured in the data panel. But I am unable to find a setting for this in the data panel. The end user will not need any JSON export options.
These are the options available. The end user will only need the csv option.
This is what I see when I try to configure the settings to only export csv files:
Any suggestions?
Thank you
JeffreyThompson2
MVP Regular Contributor
You are not missing anything. There is currently not an option to disable certain types of data downloads. It would be a good option as most people would have no idea what to do with a JSON or GeoJSON file. Some users will also have the option to make a Portal item, which could lead to a lot of clutter in the Portal. It doesn't look like anyone has posted this on the Ideas Board yet, so I think you should add it.
https://community.esri.com/t5/arcgis-experience-builder-ideas/idb-p/arcgis-experience-builder-ideas
GIS Developer
City of Arlington, Texas
