The full screen button on the map widget doesn't work to exit full screen - nothing at all happens when it's clicked while in full screen mode (doesn't exit full screen, and nothing logged to the console). Pressing Esc does nothing. Is the ExB team aware of this?
The extent navigation, measure, select, basemap, and layer list buttons also do nothing while in full screen mode.
Hello @JosephRhodes2 , I assume you are using ArcGIS Online, but if you are using ArcGIS Enterprise please let us know which version it is.
I enabled the Fullscreen tool of my Map Widget, and it works as I expected. Pressing Fullscreen (showing as a maximise icon) went to fullscreen, and could revert to minimised using either the ESC key, or the Fullscreen button again (now showing as a minimise icon).
What browser are you using, I tried it in Chrome & Edge ?
Can you post a sample Experience that we can try ourselves ?
Hi Chris,
Yes, I'm using AGOL. Here is an example: Address & Parcel Viewer (arcgis.com)
I see the same behavior in Edge and Firefox on Windows, as well as Safari on iOS.
Hello @JosephRhodes2 , am I missing something, your app seems to work fine for me ?
Hi Chris,
Thanks for the reply. I tested on the five devices I have available; here are the results:
I noticed that when I enter full screen on the one device that works, I get the "Press Esc to exit full screen" modal, but this doesn't happen on the other Windows devices.
Hello @JosephRhodes2 , OK, it looks like this is a bug, ref BUG-000164494, "Unable to exit full screen mode for the Map widget in ArcGIS Experience Builder on mobile devices". The bug is new (25th Jan 2024), so no workaround or timescale offered yet.
Thanks again, Chris. The Windows 11 devices where it's failing are not mobile devices (they are both Dell XPS notebooks). Would I need to open a support ticket to get these device types added to the bug description (or logged as a new one)?
Hello @JosephRhodes2 , yes I think a support ticket would be the best way to get the bug's scope in relation to Windows 11 checked, and if necessary, changed.
@ChrisUnderwood @JosephRhodes2
It's likely we are experiencing the same. I've given up trying to use full screen mode as an option whether its large, medium or small screen.
Basically the full screen mode button when clicked opens to full screen as expected and shows the button as available to select again to revert back, but when you try and do that, the button is unresponsive, trapping the user in that expanded view.
Using Chrome 121.0.6167
