I've created an experience builder to be shared with people within my organization, and have ensured all the associated feature layers, web maps, dashboards, are all shared within my organization as well. But I and other organization accounts are consistently asked for credentials despite being signed in to our accounts already.
Is there a way around this? I've seen posts asking that for experience builders shared publicly, but we would just like easy access within our organization.
Thanks!
Maya
By any chance is your app hosted on ArcGIS Online but some of your data are hosted on Enterprise and shared to ArcGIS Online via a distributed collaboration... or vice versa (app on Enterprise, some of the layers coming from ArcGIS Online, especially subscription content)? If so, it may be that you need to make some changes to how the data are shared between organizations, or perhaps look at the ArcGIS Online settings in Enterprise Portal, depending on which configuration you are using.
A good way to check your layers is by adding a new layer that is only shared with yourself to that map and saving and it should popup with a list of all the layers that need their settings changed to 'organization' just to check if you missed any.
Hi @maya_fromstein ,
Are you using Enterprise or Online? If it is Enterprise, what is the version?
Are the data all hosted?
Hi, thanks! I am using arcgis online and all the data is hosted. I've checked again as best I can to make sure everything is shared with the organization - but I don't think that's it since my supervisor can also log in when prompted.
Thanks!
@maya_fromstein Thanks for the information.Unfortunately I cannot reproduce the problem based on your description.
If you have logged in your organization, accessing or-shard application should not ask login again. Unless there is some data not shared. You may shared the application again from item page, and if there is any data not shared there will be a warning.
