Experience Builder - Related Tables and Feature Classes
215
01-18-2025 01:09 PM
Labels (2)
KateDoughty1
I am trying to using Experience Builder to visualize construction options. I have the following:
  1. Results feature class
  2. Construction segments feature class
  3. Construction options table
1 is/can be joined to 3 by ID
2 is/can be joined to 3 by ID
Essential what I want is for the user to filter by result, and for 2 and 3 to automatically update with the options.
I've tried arcade, pop-ups, etc. I really one result to show all available options based on the join, and the available options to only show construction segments based on the join.
Any help is appreciated!!
ShengdiZhang
Hi @KateDoughty1 ,
Due to some known limitations, currently, it is impossible to filter data from the Parent and Related tables simultaneously.
The message action Record selection changes - Framework - Filter data records, supports filtering related records, but you have to select a record on 1 to trigger the filter on 2 and 3.
Regards,
Shengdi
