After installing portal for arcgis 10.7 on Windows Server 2008 I am attempting to create a site and it is failing. The errors I am seeing are:
There was an error creating your initial administrator account. java.lang.Exception: Failed to initialize the database. The files belonging to this database system will be owned by user "xxxxx". This user must also own the server process. ....
initdb: could not execute command ".....postgres.exe"
In the event log I find several PostgreSQL errors:
pg_ctl: directory "xxxxx...." is not a database cluster directory.
I have no postgreSQL service listed under services.
In the portal log folder I find this: The process monitor did not find the connection to the configuration store. The site may not have been initialized.
On this server I have installed GIS Server 10.7 and have configured and tested that a cert is bound to 443 in IIS.
Any ideas would be appreciated!
Thanks!
