Get ST_GEOMETRY object's attribute
744
05-16-2022 12:09 PM
Bud
Notable Contributor
I have an SDE.ST_GEOMETRY value (Oracle 18c):
select
sde.st_geometry('LINESTRING EMPTY', 26917) as shape
from
dual
I want to select one of the ST_GEOMETRY object's attributes:
  • Entity
  • Numpts
  • Minx, miny, maxx, maxy
  • Area
  • Len
  • SRID
  • Points
How can I do that with Oracle SQL?
Bud
Notable Contributor
1. Use dot notation:
select
sde.st_geometry('LINESTRING EMPTY', 26917).len as shape
from
dual
If the shape column wasn't already wrapped in brackets via a function, then we would need to add the brackets:
select
    (shape).len
from
    my_fc
2. Or, use a table alias:
select
    a.shape.len
from
    my_fc a
3. Or, use the TREAT() function:
select
    treat(shape as sde.st_geometry).len
from
    my_fc
Although that might be misguided/unnecessary, since wrapping the column in brackets achieves the same thing (brackets is my preferred technique).
Bud
Notable Contributor
If I understand correctly, SDO_GEOMETRY has similar attributes. Additionally, SDO_GEOMETRY has methods (aka member functions):
  • Get_Dims
  • Get_GeoJson
  • Get_GType
  • Get_LRS_Dim
  • Get_WKB
  • Get_WKT
  • ST_CoordDim
  • ST_IsValid
Techniques for selecting an object's attribute
Replace value in SDO_ELEM_INFO_ARRAY varray
Modify SDO_ELEM_INFO_ARRAY of existing geometry
Bud
Notable Contributor
For my notes, the result from an object's attribute can be different than the result from the corresponding ST_GEOMETRY function:
Why is (SHAPE).ENTITY different from SDE.ST_ENTITY(SHAPE)?
