I am facing a strange behavior with a web map shared using ArcGIS Pro to the enterprise portal, I attached a video showing two maps:
- the first map doesn't have this issue, where I am using the event theme layer reading from a view with unique value symbology.
- the second map has the same data source with one difference being that I am using heat map symbology.Demo Video
when zooming out to infinite zoom the heat map goes out of its initial extent as shown in the attached video.
I am not able to sort out the behavior behind that noting that I am using ArcGIS Enterprise 11.2 and Pro 3.2
