That worked, thanks. Summarized response from security team:
In general we don't deserialize either trusted or untrusted data using Spring and we do not use spring to intercept requests. We only use spring for IOC.
Spring doesn't consider this a bug and did not "fix" it anyway. The context for CVE-2016-1000027 was an intentionally unsafe implementation of the Spring Framework.
The vendor rejects the premise of CVE-2016-1000027 as a vulnerability because it requires explicitly configuring an application to ignore the documented best practices for Spring and to intentionally write an app that accepts and deserializes untrusted data. Spring instead addressed this with documentation.
