Hello everyone,
I'm facing an issue while trying to deploy an ArcGIS Web AppBuilder application for testing purposes. Here are the software details:
- ArcGIS Enterprise: Version 10.8.1
- Application: ArcGIS Web AppBuilder
- User type & Role in ArcGIS Portal : Creator & Admin
I have created an ArcGIS Web AppBuilder application, and I want to test its deployment for one of our clients. To do this, I download the application from the portal using the dedicated option, which results in a zip file.
According to the documentation for adding a file to the portal, I navigate to "Content," "Add Item," "From Your Computer," and upload the previously downloaded .zip file. However, in the "Content" section, I don't see the option for "ArcGIS Web AppBuilder Application" or any other options related to applications (see attachment). Depending on the content type I select, the file gets hosted on the portal, but it doesn't appear as an application; it's just a hosted zip archive.
I'd like to mention that at one point, I tried to create a custom widget, and I encountered the same issue. I couldn't add it due to the absence of the "custom widget" option.
Any assistance on resolving this issue would be greatly appreciated.
Thank you for your help.
Best regards,
