Working with real-time data we often need to create live heatmaps based on dynamic attribute values. One example would be to create a heat map of moving vehicle speed or any other operational parameter, like engine temperature. As of right now, we need to create events (incidents) and then use their location to create a live Heat (Density) Map.
Another example would be to display the number of visits to a location using a heatmap. Each location has an attribute with a number of visits and that value should be used to create a heatmap symbology.
