I would like to suggest that the functionality be added to Drone2Map to allow for the direct export of the finished imagery into an Geodatabase from Drone2Map. Yes Pro will do it, but I am hoping because both products are part of the ESRI ecosystem, that this would be a possible option.
This is possible, create image collection then export raster button.
hi Brig. I'm going back through old ideas - I don't know if you still want this, but could you clarify why you would want the output imagery to be inside a geodatabase? For almost 12 years I've been advising users *not* to store imagery inside a GDB.
