Hi, This may have been answered elsewhere, but I have searched high and low to no avail. Is it possible when creating a series chart based on 1 data layer in an Operations Dashboard to have the x-axis pull data from one field and the y-axis pull data from another field? Both fields are included in the schema of the data layer the Series Chart is referencing. I am only able to plot more than 1 field as either separate series on 1 axis or separate categories on 1 axis.
I am trying to achieve similar results to charts I have created in ArcGIS Pro that have different fields plotted on each axis to display trends in the scatter plot (see attached image). I was trying to avoid exporting the plots out as images to embed in the dashboard. I would like the data points represented in the series dynamically changing from filters that I select in the left panel. I can see how to achieve this through actions placed on the filters, but I need the data plotted appropriately first. Thanks in advance!
