Relate layers and table
581
12-12-2022 06:11 PM
Labels (3)
RaynerCastro
Hello! I hope you can help me. I have a state layer and a table that contains a list of projects carried out in each state. I would like to configure the filter so that the states where a certain type of project has been carried out appear in the map.
Thanks!
AndreasHall
This can be achieved in many ways as long as you have a field to in both the table and the layer that can be used to join them together (supposedly the state name in your case). You can create a category selector based on the categories in the table and in that selector configure an actions that filters the map. Then you define the source field and target field that this action should be based upon. A similar solution is available in the serial chart and other elements.
