I have a dashboard that contains 2 pie charts, a map, a list and a TOC. One of the pie charts was created using a Data Expression and the other was created using a hosted feature layer. They are identical except that the one created with the data expression has no available actions.
In my data expression, I set the includeGeometry parameter to TRUE in the FeatureSetByPortalItem function. I also reference the geometry when I populate the feature array and when I define the dictionary.
In the map, I am able to assign a Filter to both pie charts and the list.
So when I zoom in and zoom out of the map, both the pie charts and the list change based on the extent of the map.
The issue is when I click on a slice of the pie chart. Is it even possible to update the display of the map from a chart that is created from a data expression?
I want to be able to click on a slice of the pie chart created using a data expression so that it filters the map like the one created using a hosted feature layer.
Filtering the pie charts from the map works great
Once I know if this is even possible, I'll post the data expression code.
Thanks in advance.
Teri
