I have created a dashboard to monitor our hydrant inspections. I have configured a list element that has a list of all the inspections that are due to be inspected. I configured it so that when you click on one of the hydrants in the list it will flash and zoom to the hydrant. However, when I click the hydrant from the list and it zooms in, it is not showing the hydrant layer only the hydrant inspection layer (different point layer). If I zoom out and zoom back into the same hydrant inspection manually, then it will show the hydrant layer. It works fine in ArcGIS online. I am not sure if this is a glitch or not. The first picture is if I just zoom into the map manually.
Solved! Go to Solution.
Can you select the Source and Target Field for the Hydrant?
Not sure what that is... Is there only one inspection in the list or more?
I would try to use a selector to see if the behavior is the same. And also try to change the layer order in your map to see if that is changing something. I don't know what I would do then from the result but it would confirm that the behavior is consistent (or not).
I have done the selector and the result is the same. I have also reordered the layers and its the same thing. I even turned off the hydrant inspection layer in the map and it shows nothing beneath the point.
How weird. What are the action settings on the list/selector?
Doing that worked! Thank you very much @Nicole_Ueberschär!
