Hi Sarah,
The ArcGIS geodatabase model only allows for one single SHAPE (geometry) column per feature layer, so this restricts the number of geo questions you can add to a survey to one: either one geopoint, or one geoshape or one geotrace question.
You can add multiple map questions to your survey, but only the first map is being recorded in your data. If you look at your survey in the web designer you would notice that your second map has been set to 'do not submit the answer'.
The ability to add a second map question to your survey allows users to use the response in additional calculations. If you need to capture additional geometry information, you would need to use Survey123 Connect, and add your second map question in a repat.
This blog article goes into using repeats to add additional geography questions.
- Jen
