Hi all,
I am brand new to Arcade Expressions and I am wondering if I can do what the title states. I found this resource
"Join attributes from a layer to a table"
I've tried emulating it with no avail (see reply below).
Currently I have two lists but its a bit awkward as the lists can't filter all the category selectors. Which in turn can't filter my Pie Chart (which is a sum of the "replacement_cost" field of the grouped field "Condition_Rating".
Any guidance on this matter?
So far this is what I've done but when I enter it as an arcade expression into a pie chart or a serial chart, the expression fails and i get no error or return in the Message box. It also says that my expression is invalid. Not sure what to exactly do.
var portals = Portal("Portal URL");
var pointfs = FeatureSetByPortalItem(
portals,
"Item ID",
0,
false
var tablefs = FeatureSetByPortalItem(
portals,
"ItemID",
5, //this is a sublayer item id of 5
false
// Create empty features array and feat object
var features = [];
var feat;
// Populate Feature Array
for (var t in tablefs) {
var tableID = t["Asset_ID"]
for (var p in Filter(pointfs, "Asset_ID = "+tableID)){
feat = {
attributes: {
Asset_ID: tableID,
// Fields from pointfs
Building_Name: p["Building_Name"],
Facilities_Building_ID: p["Facilities_Building_ID"],
GIS_Building_ID: p["GIS_Building_ID"],
Uniformat_Code: p["Uniformat_Code"],
Uniformat_Name: p["Uniformat_Name"],
Assessment_Description: p["Assessment_Description"],
Component_Manufacturer: p["Component_Manufacturer"],
Unit_Cost: p["Unit_Cost"],
Assessment_Qty: p["Assessment_Qty"],
Expected_Useful_Life: p["Expected_Useful_Life"],
Replacement_Cost: p["Replacement_Cost"],
// Fields from tablefs
Condition_Rating: t["Condition_Rating"],
Condition_Narrative: t["Condition_Narrative"],
Recommendation_Year: t["Recommendation_Year"]
Push(features, feat)
var joinedDict = {
fields: [
{ name: "Asset_ID", type: "esriFieldTypeInteger" },
{ name: "Building_Name", type: "esriFieldTypeString" },
{ name: "Facilities_Building_ID", type: "esriFieldTypeString" },
{ name: "GIS_Building_ID", type: "esriFieldTypeString" },
{ name: "Uniformat_Code", type: "esriFieldTypeString" },
{ name: "Uniformat_Name", type: "esriFieldTypeString" },
{ name: "Assessment_Description", type: "esriFieldTypeString" },
{ name: "Component_Manufacturer", type: "esriFieldTypeString" },
{ name: "Unit_Cost", type: "esriFieldTypeDouble" },
{ name: "Assessment_Qty", type: "esriFieldTypeDouble" },
{ name: "Expected_Useful_Life", type: "esriFieldTypeDouble" },
{ name: "Replacement_Cost", type: "esriFieldTypeDouble" },
{ name: "Condition_Rating", type: "esriFieldTypeString" },
{ name: "Condition_Narrative", type: "esriFieldTypeString" },
{ name: "Recommendation_Year", type: "esriFieldTypeDouble" }
geometryType: 'esriGeometryPoint',
features: features
// Return dictionary cast as a feature set
return FeatureSet(Text(joinedDict));
