I have a composite address locator that has the following participating locators:
- Full Address (points)
- Street Centerline (for when an exact address match isn't found)
- Parcel APN (used when an address field isn't populated)
- Historical Parcel APN (when a record needs to be matched to an old parcel number)
I have a dataset with about 40k records that I geocoded using the composite locator and it matches all but ~800 of the records to the FullAddress locator using an Address field from the data.
Unfortunately when I try to pan to or zoom to individual locations on a map, it doesn't go anywhere... So I calculated x/y geometry but they all have no spatial location even though they say they matched...
Curious if I did something wrong creating the composite locator becuase when I use the FullAddress locator on its own it returns spatial information no problem.
Anybody else have an issue like this and have a solution?
Are you using the new style locators (Create Locator) and merging them into a composite locator by any chance? If so, this thread has relevant information.
The bottom line is, while it's technically supported, new style locators and composite locators are virtually unusable.
Kyle:
I don't see anything in comment you linked to that would lead me to believe the new locators and composite locators are unusable. Could you elaborate on your comment? I would definitely recommend using a multirole locator created with the Create Locator tool over a composite locator, but in a few instances you might find the need for a composite locator.
Shana,
Reverse geocoding does not work at all when mixing new locators and composite locators, that's a pretty important feature. Brad even says it's inadvisable to mix the new technology with the old, and it should only be used as a last resort or you have no need for reverse geocoding.
Kyle,
Your statement that "Reverse geocoding does not work at all when mixing new locators and composite locators" is not correct. The composite locators function and return results correctly but you will have less output than you would when using the new locator by itself. This is how the classic locators worked and how the classic locators inside of composite locators worked. With the composite locator that contains the newer locators created with the Create Locator tool, you will only get back the parsed out address for the reverse geocoded location instead of additional geocoding metadata that the mutlirole new locators return.
Brad
Kevin:
