3D Buildings elevation
540
08-04-2021 11:31 PM
Mokwena9
I have used the 3D Basemaps Solution to create 3D buildings using LiDAR and Building footprint by following the working within the solution. My problem is that the resulting Multipatch Buildings “fall into the ground” it only shows the roof, and not the walls
I have the ground elevation source (DTM) created from LiDAR, which was also used to create the ground surface of these buildings
Is there a way I could use to display the buildings at an accurate height/elevation?
