Try to add a graphic layer but got 'TypeError: this.map.addLayer is not a function
5555
10
05-20-2023 09:04 AM
chunguangWayneZhang
This is something kind of puzzle me. Hope someone can help.
I have a queried feature set that I want to add to the map as a graphic layer.
I have a cope of codes that seems in the right scope with lang.hitch included in the function queryfeatures. but somehow I couldn't get rid of the this.map.addLayer(myGraphicLayer) with 'TypeError: this.map.addLayer is not a function error. I checked community. The error is most like caused by out of scope. But it seems it is not the issue. Thanks for you help.
layer.queryFeatures(featureQuery, lang.hitch(this, function (featureSet) {             //there is a lang.hitch here
                  if (featureSet && featureSet.features.length > 0) {
                    var parcelSymbol = new SimpleFillSymbol(SimpleFillSymbol.STYLE_SOLID,
                      new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID,
                        Color.fromArray([0, 255, 255]),
                        //new Color([0, 255, 255]),
                        4))
                    var marketgraphics = new GraphicsLayer({
                      graphics: featureSet.features
                    this.map.addLayer(marketgraphics);  //here is the error
KenBuja
MVP Esteemed Contributor
Since it's being called within the showResult function, you'll have to add the lang.hitch here
queryTask.execute(query, lang.hitch(this, showResults));
KenBuja
Are you calling that inside another function? If so, you probably don't have lang.hitch when calling that higher function.
chunguangWayneZhang
Thanks for your help. The whole function is inside  layer.queryFeatures( which is the first line here and ends the last line with ). The this.map works on other functions.
                        4))
                    marketgraphics.renderer = new SimpleRenderer(parcelSymbol);
                    marketgraphics.graphics = featureSet.features;
                    marketgraphics.redraw();
                    jimuUtils.zoomToFeatureSet(this.map, featureSet).then(null, function (err) {
                }), lang.hitch(this, function () {
KenBuja
Are you using that snippet inside of another then statement? As an example, I have to use lang.hitch several times in this code that does authentication
   esriId
      .getCredential(info.portalUrl, {
        oAuthPopupConfirmation: true
      .then(
          this._portal = new arcgisPortal.Portal(this._portalUrl);
          this._portal
            .signIn()
            .then(
              lang.hitch(this, function (portalUser) {
                this.welcomeNote.innerHTML =
                  this.nls.welcome + portalUser.firstName + "!";
                const portal = portalUser.portal;
                const queryParams = {
                  num: 100,
                  q: 'owner: ' + this._ownerName + ' AND type: "Feature Service" AND title: "' + this._baseGridLayerName + '"'
                portal.queryItems(queryParams).then(
                  lang.hitch(this, function (result) {
                    if (result.total > 0) {
                      if (
                        array.some(
                          result.results,
                          lang.hitch(this, function (item) {
                            if (item.url !== null) {
chunguangWayneZhang
Actually, it is not called in another then statement or function. Just inside that layer.queryFeatures function. The layer.queryFeatures function is in a ELSE statement.
Thanks again
KenBuja
Can you post the entire function?
chunguangWayneZhang
This seems has issue with a post. Tried several times to post the whole function but doesn
chunguangWayneZhang
Yes, here is the whole function in the if () statement. There is lang.hitch as well. Thanks
 if (layerInfo) {
          layerInfo.getLayerObject().then(lang.hitch(this, function (layer) {
            var gs = getGraphics(layer, resultFeature.attributes[layer.objectIdField]);
                new Color("purple"),
               4))
            if (gs && gs.length > 0) {
              var queryTask = new QueryTask(this.nls.marketTbl);
              var query = new esri.tasks.Query();
              query.returnGeometry = false;
              query.outFields = [
                "PIN", "COMPPARCEL1", "COMPPARCEL2", "COMPPARCEL3", "COMPPARCEL4", "COMPPARCEL5"
              query.where = "PIN ='" + gs[0].attributes["PIN"] + "'";
              console.log("PIN ='" + gs[0].attributes["PIN"] + "'")
              queryTask.execute(query, showResults);
              function showResults(results) {
                var resultItems = [];
                var whereclause = "";
                var resultCount = results.features.length;
                if (resultCount >= 1) {
                  for (var i = 0; i < resultCount; i++) {
                    var featureAttributes = results.features[i].attributes;
                    for (var attr in featureAttributes) {
                      resultItems.push(attr + ":" + featureAttributes[attr]);
                      whereclause += "PIN ='" + featureAttributes[attr] + "' OR ";
                  console.log(whereclause)
                else {
                  console.log("Can not find market model parcels")
                  return;
                 var featureQuery = new FeatureQuery(this.parcelFC);
                featureQuery.where = whereclause.slice(0, -3);
                //featureQuery.where = "(UPPER(PIN) = '16074500690') OR (UPPER(PIN) = '16096000350' OR UPPER(PIN) = '16074400610') OR(UPPER(PIN) = '16074400720') OR(UPPER(PIN) = '16074400630')";
                console.log(whereclause.slice(0, -3))
                //featureQuery.where = whereclause.slice(0, -3);
                featureQuery.outSpatialReference = this.map.spatialReference;
                featureQuery.outFields = ["*"];
                featureQuery.returnGeometry = true;
                    4))
                layer.setSelectionSymbol(parcelSymbol);
                layer.selectFeatures(featureQuery, FeatureLayer.SELECTION_NEW, lang.hitch(this, function (results) {
                        4))
                    jimuUtils.zoomToFeatureSet(this.map, featureSet, 1.8).then(null, function (err) {
chunguangWayneZhang
Tried to post entire function but won't allow me to post it somehow. Here is the top part and the next following part was posted before. Thanks.
      if (layerInfo) {
                4))
              query.outFields = [
                else {
                  return;
                    4))
KenBuja
