Reproject a Graphic from 102100 to 4326
6107
12
09-25-2015 09:07 AM
FlorianCADOZ
Here I have two graphics ( one is a polygon and the other one is compound of several points ) and my objective is to produce something that looks like this: ArcGIS API for JavaScript Sandbox
My problem is that the polygon is in 4326 , the map is apparently (not sure ) in 102100 , and the points are in 4326 and apparently I have a problem when using this function:
        relationParams.geometries1 = graphicsUtils.getGeometries([this.entry4Analysis.featureSet.features[0]]);
        relationParams.geometries2 = graphicsUtils.getGeometries([this.spatialFilter4Analysis.graphics[2]]);
        relationParams.relation = RelationParameters.SPATIAL_REL_WITHIN;
        this.geometryService.relation(relationParams, this.addRelateResultsToMap);
So I tried different syntax (like : .setOutSpatialReference) to change the projection of one or other of the graphics when I launch the spatial analysis but nothing happens...
So now I really need help...
Thank you very much by advance !
FlorianCADOZ
woh' I really don't understand why the this.spatialFilter4Analysis.graphics[2].geometry return a different thing that the graphicsUtils.getGeometries([this.entry4Analysis.featureSet.features[2]]) but right now ain't got no error with the .contains() function !
Nevertheless, ain't got any alert so it didn't found points in my polygon and this is not normal...
Do you know if the different spatial reference could be a raison of this fail ?
For now, I need to specify a polygon in particular but in a second time I will have to use different polygon so I think I'll try to make an union of them !
(Thanks a lot for your last comment, it was really usefull!)
RobertScheitlin__GISP
Florian,
    Since your points are 102100 and your Poly is 4326 you can just use esri/geometry/webMercatorUtils to project your points to geographic (4326) before you try the poly.contains.
var point = webMercatorUtils.webMercatorToGeographicthis.entry4Analysis.featureSet.features[0].geometry);
if(poly.contains(point)){
    alert('hello');
FlorianCADOZ
Yes It was exactly that ! Thank you very much for your help !!!
