Re: Is there a way to change the column names in the attribute table for the search results of the enhanced search widget?
3684
13
01-12-2016 07:25 AM
RudoDuncan
Sorry, is there a way to make one of the fields in the pop up a hyperlink?
MichaelRobb
Honored Contributor
Hello Robert.
I interpreted the 'sorry'... after the title question as....
, the title was different than what the original question was intended... as I know one is not able to 'edit' the heading title of a thread once it has been created..   Since the question is "Is there a way to change column names in the attribute table"  has nothing in relation to a popup, or does it? Hence the confusion.. sorry. ... I assumed it was regarding hyper link in popups, not column names in attribute tables... but maybe Rudo was still referencing the Enhanced Search Widget but for popups, rather than column names...
Rudo does have both avenues to his question(s) now...
Have a good day.
RobertScheitlin__GISP
Michael,
  I branched this from another thread as it was a different question, so this likely lead to the confusion.
RudoDuncan
I have a decent start on the configs for my widget. Is there a way to make the drop menu load faster when I choose "UNIQUE"? There are multiple fields that I want unique but it is trying to load over 2 million records.
My second question is after I am satisfied with my configs. How do I add that widget to my local widget folder? For some reason when I zip my test map and add it, your configs pop up in web app-builder.
I am sorry for bombard you with question but I am new to the develop side of this. Thank you for your patience.
Rudo,
  Querying 2 million record is not practical using web apps. There is no way to speed that up. You should not use Unique in that situation. Use Value or Predefined.
Your second question is confusing. Normally you download a custom widget and add it to the client stemapp folder as you are picturing above. Then you create a new app and add the custom widget to that app using the widgets tab in WAB and then once you have your app completely configured then you download the app from the wab main window and deploy this zipped app to your production web server.
Just some forum etiquette when you ask a question and it has been answered you mark the reply that answered your question as the correct answer. If you have another question that does not relate to the first then you start a new discussion/question.
