Public Notification Widget in ArcGIS for Portal 10.5.1 - generate mailing labels in pdf or csv not working
2003
05-04-2018 02:10 PM
BPriyaK
With great help from the GeoNet community ,I was able to get the Public Notification Widget from WAB developer edition into our organizations portal (version 10.5.1).
The problem I'm encountering now is that the even after setting up the Addressee layer and notification options to pdf and csv for the widget. the widget becomes non responsive and won't generate any labels.
seeking advice and guidance from folks that may have successfully accomplished this.
Image showing widget status after making a seletion using polygon tool.
Thank you
Bhanu
BPriyaK
Changing the Geometry service Url made the difference and i got the widget working.
BPriyaK
ChetShuler
What did you change it to?
ChetShuler
I got it working. When I configured my custom pops I used proper case for the field names. Pop ups worked fine but I still could not export. I re-built the custom pops and by accident used all uppercase which matched the headers fields in my address layers. Ta Da working good. Still would be nice to have it export the headers to the csv file.
