Super generic, I know but thought I'd see if anyone has run into this.
We have a custom print service that use .mxd source templates (v10.8.1) and a custom widget that prepares the webmap_as_JSON input parameter. The mxd has an empty legend associated with the data frame and all seems to work except for 1 minor issue: the polygon patch in the legend does not print the outline, only the fill shows up.
Before I get too deep into posting code, just wondering if anyone has run into this!
j
Here's the execute task's Web_Map_As_JSON parameter in the request to the print service. It's the "Selected Applications" that should be one I'm interested in:
"mapOptions": {
"showAttribution": true,
"extent": {
"xmin": -8979745.169338416,
"ymin": 3157283.911112111,
"xmax": -8943055.395761583,
"ymax": 3175189.284987889,
"spatialReference": {
"wkid": 102100,
"latestWkid": 3857
"wkid": 102100,
"latestWkid": 3857
"scale": 72223.819286
"operationalLayers": [
"id": "layer3",
"title": "layer3",
"opacity": 1,
"minScale": 0,
"maxScale": 0,
"url": "https://services.arcgisonline.com/ArcGIS/rest/services/World_Imagery/MapServer"
"id": "layer2",
"title": "layer2",
"opacity": 1,
"minScale": 0,
"maxScale": 0,
"url": "https://blahblahblah/Transportation/MapServer"
"id": "Selected Application",
"opacity": 1,
"minScale": 0,
"maxScale": 0,
"featureCollection": {
"layers": [
"layerDefinition": {
"name": "Selected Application",
"geometryType": "esriGeometryPolygon",
"drawingInfo": {
"renderer": {
"type": "simple",
"label": "Application",
"symbol": {
"color": [
255,
170,
0,
255
"outline": {
"color": [
255,
170,
0,
255
"width": 1.875,
"type": "esriSLS",
"style": "esriSLSSolid"
"type": "esriSFS",
"style": "esriSFSBackwardDiagonal"
"featureSet": {
"features": [
"geometry": {
"rings": [
-8961855.5314,
3165742.8092
-8961856.1841,
3164886.830600001
-8961855.5314,
3165742.8092
-8960040.978,
3170422.6761999987
-8960040.7589,
3170422.4426000006
-8960040.978,
3170422.6761999987
"wkid": 102100,
"latestWkid": 3857
"id": "printOutlineLayer",
"opacity": 1,
"minScale": 0,
"maxScale": 0,
"layers": [
"name": "polygonLayer",
"featureSet": {
"features": [
"geometry": {
"rings": [
-8964510.31413835,
3158627.702797455
-8964510.31413835,
3158965.5257343827
-8958290.25096165,
3158965.5257343827
-8958290.25096165,
3158627.702797455
-8964510.31413835,
3158627.702797455
"wkid": 102100
"symbol": {
"color": [
255,
0,
0,
204
"type": "esriSFS",
"style": "esriSFSSolid"
"geometry": {
"rings": [
-8968726.374969315,
3159006.816093703
-8954074.190130685,
3159006.816093703
-8954074.190130685,
3173466.3800062975
-8968726.374969315,
3173466.3800062975
-8968726.374969315,
3159006.816093703
"wkid": 102100
"symbol": {
"color": [
255,
0,
0,
102
"outline": {
"color": [
255,
0,
0,
255
"width": 3.75,
"type": "esriSLS",
"type": "esriSFS",
"style": "esriSFSNull"
"name": "textLayer",
"geometryType": "esriGeometryPoint"
"featureSet": {
"geometryType": "esriGeometryPoint",
"features": [
"geometry": {
"x": -8961400.28255,
"y": 3158796.6142659187,
"wkid": 102100
"symbol": {
"color": [
0,
0,
0,
255
"type": "esriTS",
"verticalAlignment": "middle",
"horizontalAlignment": "center",
"angle": 0,
"xoffset": 0,
"yoffset": 0,
"text": "Pan or Zoom the map to adjust this print area.",
"rotated": false,
"kerning": true,
"font": {
"size": 12,
"style": "italic",
"decoration": "none",
"weight": "normal",
"family": "Arial"
"id": "Canal Center Line",
"title": "Canal Center Line",
"opacity": 1,
"minScale": 0,
"maxScale": 0,
"drawingInfo": {
"renderer": {
"type": "simple",
"symbol": {
"color": [
17,
0,
148,
255
"width": 0.75,
"type": "esriSLS",
"url": "https://blahblahblah/MapServer/7"
"exportOptions": {
"outputSize": [
800,
1100
"dpi": 96
"layoutOptions": {
"customTextElements": [
"county": "blah"
"appNo": "blah"
"str": "blah"
"exhibitno": "blah"
"permitno": "blah"
"projname": "blah"
"scaleBarOptions": {},
"legendOptions": {
"id": "Facilities Layer"
