Minimize AttributeTable Widget
1701
02-07-2017 04:42 AM
GilbertoMatos
Hello!
I mounted a custom buffer widget. I need that after the user clicks on the "Clear Buffers" button, if the attributetable widget is open (taking the bottom of the screen, for example), it is minimized. I tried the following way and I did not succeed. Any help
will be welcome.
NOTE: The close option works correctly, but minimizing does not occur.
Thank you!
this.wManager = WidgetManager.getInstance();
if (this.wManager)
        var widgetCfg = this._getWidgetConfig('AttributeTable');
        if (widgetCfg)
                var attWidget = this.wManager.getWidgetByLabel(widgetCfg.label);
                if (attWidget)
                        //Works correctly
                        //this.wManager.closeWidget(attWidget);
                        //It does not work properly
                        this.wManager.minimizeWidget(attWidget);
RobertScheitlin__GISP
Gilberto,
  You need to call the _closeTable method in the Attribute Table Widget:
if (this.wManager) {
        if (widgetCfg){
                if (attWidget){
                        attWidget._closeTable();
Gilberto,
        if (widgetCfg){
                if (attWidget){
GilbertoMatos
It worked correctly!
Thank you Robert!
Gilberto.
