How to make the search bar open at start?
3163
11
10-05-2017 03:13 PM
RobertScheitlin__GISP
I don't do much work with story maps but if you know the file that the Search widget is created in the in the constructor there will be a enableButtonMode property or you can just invoke the expand() method on the Search dijit.
Brandon,
   I don't see an attached file and the WAB search widget is opened by default so this question has me scratching my head.
BrandonPrice
Hi Robert,
The search bar is actually in a story map. Mine doesn’t open on default. I do not why the attachments were not attached. I have tried to attach them again.
Brandon
BrandonPrice
Thanks Robert. I was able to do this in the viewer-min.js file of the story map by changing the enableButtonMode for the geocodercontainer from !0 to !1
Best,
Brandon
Great don't forget to mark this as answered then.
BrandonPrice
Ok. Sounds good.
RickeyFight
MVP Regular Contributor
I was able to get this to work but would there be a way to make it stay the button version for mobile devices?
Code here:
function c() {
 var e = $(r.container).find(".geocoderBtn");
 f = n.createGeocoder({
 map: r,
 domNode: e.find(".geocoderContainer")[0],
 enableButtonMode: !0,
 searchOptions: o
 }).then(function (t) {
 a = t, e.find(".esriGeocoderContainer input, .esriGeocoderSearch").attr("tabindex", "-1")
RickeyFight
Never mind I figured it out
BrandonPrice
Hey Ricky,
Are you saying have it still be closeable? I haven’t figured that one out yet.
-Brandon
