Hi all,
I'm attempting to fix a number formatting issue in the edit pop-up in a web appbuilder application. The application seems to ignore my format code (probably because I'm doing it wrong). I would like the numbers to display without the thousand separator but I'm not able to make changes appear when I edit the config_Edit.json file. Is it being over-ridden by something else in the code? Any ideas would be helpful.
I would also like this in the default pop-up without having to edit the pop-up in ArcGIS Online. Pure laziness on my part; I already need to make application code changes and hitting the pop-ups is easier for me than using the AGOL user interface.
