How can I include the help file of a custom wiget in Portal?
1665
03-11-2021 05:18 AM
by Anonymous User
Not applicable
I know the way to add help file of a custom widget in wab developers:
https://developers.arcgis.com/web-appbuilder/guide/add-help-for-your-widget.htm
But in Portal the 'docs' folder doesn't exist.
I would like to know if it can be made and if it's possible I would need to know the workflow.
Best regards.
JayantaPoddar
I believe the "~/docs" folder referred here is under ArcGISWebAppBuilder directory (Unzipped from the WAB-Dev Edition zip file).
Think Location
by Anonymous User
Not applicable
thank you @JayantaPoddar but it's for developer edition as I commented.
My doubt is the same procedure for portal version, because docs folder doesn't exist.
RobertScheitlin__GISP
Ester,
   The way that I handle this in my custom widget is to have a help folder under the widgets main folder and apply this hack to the setting.js of the widget.
 setConfig:function(config){
      //hack the 'Learn more about this widget link'
      setTimeout(function(){
        var helpLink = dojo.query('.help-link');
        helpLink[0].href = this.configWindow.esri._appBaseUrl + 'widgets/eSearch/help/eSearch_Help.htm';
        html.setStyle(helpLink[0],'display','block');
      },600);
      this.config = config;
