Dead End : eSearch Not Loading Anything
5489
9
05-27-2016 09:42 AM
BrianO_keefe
Honored Contributor
I'm developing a Web App for Collisions in Tulsa.
I built the MXD. It uses a Query Layer that pulls from some Oracle DB's.
I Shared the MXD as a REST Service.
I built an AGOL map using that REST Service.
I built a WAB App using that AGOL Map.
I added in the eSearch widget ( the one published on 23MAY ).
( thanks to creator Robert Scheitlin, GISP​ )
Configured it with my REST Service.
I'm getting nothing...
ArcGIS Web Application
There is the link to the sandbox version of it.
I spent more than a few hours yesterday trying to figure it out. I'm at a loss. About to go back to the early version of the eSearch.
Tags (1)
RobertScheitlin__GISP
Brian,
  There seems to be some issue with your map service when it comes to that particular date field. Here is what I am seeing:
This query using your map service REST endpoint works fine (returns 24 records)
INCIDENT_START_DATE BETWEEN timestamp '5/13/2016 00:00:00' AND timestamp '5/13/2016 23:59:59'
This one using the date date returns no results.
TPD_COLLISION_DATEBEGIN BETWEEN timestamp '5/13/2016 00:00:00' AND timestamp '5/13/2016 23:59:59'
Actually I can not get any TPD_COLLISION_DATEBEGIN query to work.
RickeyFight
Brian,
I get data when I select by shape.
This is my map for Traffic accidents for my city. ( I cannot share webmap because the map is private)
But here is a screen shot. The user can filter by everything but day all at once.
BrianO_keefe
Honored Contributor
*pinching the bridge of my nose*
Ok... I'm getting something back from there as well. So search by shape works... but nothing in regular searching?!
So confused... I think I'm MORE confused now than I was before... lol
RickeyFight
Brian,
I think you are doing your widget set up wrong. I go it to work using your data.
What does your widget search layer look like?
This is WAB 2.0
BrianO_keefe
Honored Contributor
Technically now I get double eSearch options when trying to re-add the widget...
I feel like I'm falling in the rabbit hole...
RickeyFight
One option is to delete them both, re-import the widget after a fresh download and then start a new project.
BrianO_keefe
Honored Contributor
That's the thing. In the actual FOLDERS in Windows Explorer, there is only one... But when I go to add a widget... there are two.
RickeyFight
That is strange.
I would delete the one folder and re-add download it.
Brian,
BrianO_keefe
Honored Contributor
That was totally it...
