Changing zoom scale for Search widget
5894
12
09-07-2016 01:53 PM
AndrewL
According to this documentation I can change the zoom level for the Search widget. I have tried it several times but don't see any changes. I save the app every time then relaunch. Shouldn't this change the initial zoom level after you enter an address? Every time I change it it zooms to the same extent however. Maybe I am missing something. Thank you!
Be default, zoom scale is defined as 1:50,000. Change it if necessary.
Search widget—Web AppBuilder for ArcGIS | ArcGIS
RobertScheitlin__GISP
OK,   So I think the issue is that the zoomScale is only used is the locator does NOT return a extent.
If the result does not have an associated extent, specify this number to use as the zoom scale for the result.
deleted-user-CQZbjNeBXm49
Hi Robert,
Yes you are right, only works with locators without extent
Baba
JordanValen1
Hi Baba,
Can you elaborate on this?  I'm having this issue - cannot for the life of me change the zoom when you select from the search list.
Jordan
