Changing label value from number to text.
1545
09-06-2018 05:44 AM
SivaramKrishnan2
Hi
I'm creating a feature layer dynamically from a query result from the web service in WAB 2.6
I'm trying to set the label in the output feature layer using the following snippet.
and i'm getting the following result.
I need to consolidate the number values present in the label to some currency representation instead of plain numbers.
kindly help me to resolve this.
Thanks & Regards
Siva
RobertScheitlin__GISP
Siva,
   This should work:
        var json = {
          "labelExpressionInfo": {"value": "${" + this.secValueName + "}"},
          "fieldInfos": [{fieldName: this.secValueName, format: { "digitSeparator": true}}]
Siva,
   This should work:
        var json = {
