Attribute Table Fields Formatting
3981
02-03-2016 11:33 PM
MajdiTurkman1
Hello,
I'm trying to format attribute table fields, such as the following:
  • Date time Field: show date only without time.
  • Number field: add dollar sign and format the value to have decimal separator.
  • Text field: show only the first 50 characters and append "...".
Any Idea?
Thanks.
RobertScheitlin__GISP
Majdi,
  Here is a thread on where you can adjust the date portion in code:
Attribute Table Widget: Removing Time from DateTime Field
There is no configuration for formatting fields in the AT widget.
I have not seen any threads on adjusting numeric formats.
AnninaHirschi_Wyss1
Hi mfet_glory,
I don't know if you resolved this question already, it's been a while. I reply, because I just stumbled upon the same issue.
At least for the time and digits, you have to specify this in the Web Map Pop Up. -> Open the layer (or table) pop up, click on "configure attributes". Even if you have a custom attribute display, these configurations are reflected.
Best,
Annina
