Adding a Definition Query to Select Widget
4533
10
01-31-2019 09:03 AM
TylerDunn2
So here's the background:
I'm trying to use the Select widget to hit 3 layers in my map, but apply a different Census population to each layer.
The layers are Single Family Attached (I want the selection count *3.02), Single Family Detached (I want the selection count * 3.02) and Multi Family (I want the selection count *2.82). This will allow our planners to estimate population in areas of the city. My issue is that I cant figure out a way to define which layer I want to be applying the multiplier to. When I write:
this.own(on(this.featureLayer, 'selection-complete', lang.hitch(this, function(){
var selectedCountSfaPop = this.featureLayer.getSelectedFeatures().length * 3.02;
it applies that to all three layers. When I console.log the layerObject, it returns the 3 layers, but I cannot for the life of me figure out how to separate the layers out for their individual Select and multiply.
I see 2 ways about it:
1) have 1 layer and do 3 definition queries in the script to do the multiply.
2) have 3 layers and within the script specify which layer I'm hitting and do that 3 times.
Anyone have any suggestions??
RobertScheitlin__GISP
The same place you had it initially.
  var selectedCountSfaPop = null;
  if(this.featureLayer.title === "x"){
  }else{
    selectedCountSfaPop = this.featureLayer.getSelectedFeatures().length * 2.82;
Tyler,
  Don't the layer has a different ID?
TylerDunn2
They do all have different ID's, but when I try to pinpoint the layer, it seems like it return the ID number, or the layer name, not the actual layer: I also might be doing it in the wrong place. I've tried with layerObject.id, getSelectedFeatures(["1"]) and a few other spots. Where would be the best spot to call the IDs?
Tyler,
  OK, I am a little confused. You have:
Do you not know which layer this.featureLayer references?
TylerDunn2
this.featureLayer is referencing all 3 layers, that's what I'm trying to limit:
It's really just the same feature service (AddressesWithCOs) added to the map 3 times, and a filter applied to each. So when expanding the console information, they all have different names (same as what's in the config file )and IDs. I just can't figure out where or how to specify. Would it be easier if they're all in the same feature service and query them out by URL rather then a layer property?
Tyler,
  So can you distinguish them based on the layer.title?
TylerDunn2
Would I attach that to this.featureLayer = layerObject at the start? Or would that get attached further down:
Tyler,
  No, I was asking you to see if the layer.title (which should already be populated) could help you determine which layer you are dealing with and thus what multiplier to apply.
TylerDunn2
Yeah it definitely could, all the layers pull in their unique title and the ID. My issue is where to code that into the script
  }else{
